connection with modem on accesspoint
  • 3 October 2019
  • 378 Bekeken
Hi! I am trying to set up my modem, however the cable connection, which I have in my apartment is not DSL. Picture attached. What type of adapter shall I look for? Thanks in advance!
Beste antwoord door Sander 4 October 2019, 11:30
Badge +14
Hi
First of all please request a moderator to change your username, your 06 number as your username is not very smart.
Badge +14
HI,
This kind of connection looks very old but normally a green cable is for cable, blue for dsl and orange for glasvezel
So when choosing the connection choose cable connection I guess.
problem resolved.
Badge +14
Hello
Good to hear if my tip did help you please like my comment above so this topic gets marked as solved 👍
Hi @zdravkozankov,
The picuture you placed if for the old cabled coax. You need to find this kind of connection:
Good to read that you managed to find it already!
