Dear TMobile team,
My Internet connection date was supposed to be 02-10-2019 (yesterday). I followed the installation instruction and waited until 18:00. I still have no wifi connection, the WAN light on the router is not on.
is there a reason that my connection did not happen yesterday as it was supposed to? I have had no communication to tell me of any delays.
please can anyone help?
no wifi or LAN connection
Beste antwoord door Piotr
Hey @jbuckley ,
I see that you've contacted my colleague and made an appointment with our engineer on the 10th of October. Our engineer will make sure that your installation will go smoothly. You can make use of your current Ziggo connection until the installation date. Welcome Thuis!😄
Bekijk origineelI see that you've contacted my colleague and made an appointment with our engineer on the 10th of October. Our engineer will make sure that your installation will go smoothly. You can make use of your current Ziggo connection until the installation date. Welcome Thuis!😄
