Odido fiber constantly dropping connection with internet, every few minutes. Delta network, Z56 modem.
Reposting because the first post did not get approved.
I installed Odido fiber with 400Mb/s package in june. Since the very beginning, all my devices kept dropping connection all the time. These are frequent, short duration (up to 15 seconds) dropouts that happen at all times of day, on all devices, both wifi and wired. These dropouts are so bad that streaming is often interrupted, and I'm often kicked from multiplayer games due to disconnections. Extremely annoying and not what I'm paying for.
I called Odido support, and they offered the usual powerflip as a solution, but I've tried that dozens of times and it has no effect. I also got a wifiversterker from Odido, which also doesn't help with dropouts (the issue was happening before as well as after I installed the wifiversterker).
I decided to log these dropouts a few times, and the screenshots below show how they usually happen. Note that this logging software only pings every 20s, so there are actually many more dropouts than what's logged, but those happened between the pings.
Will anyone from Odido look into this?
Uitgelichte reactie
9 december 2024
Hi ​@Lursmani9, welcome to our Community!
I am glad you made a thread about it. I immediately went and did a line measurement for you. I don't see anything crazy on it and everything looks fine. I also don't see the outage in my measurement, the WAN uptime is fine and matches the device uptime. What exactly are you seeing? Can you also tell exactly what devices you have on your network? Thanks in advance!
29 reacties
Forum|alt.badge.img+11
  • 14875 reacties
  • 9 december 2024
  • 18 reacties
  • 9 december 2024
That’s interesting. These dropouts happen on all devices. I use a few laptops, phones, two desktops, a TV, and a Samsung Smartthings hub. All these devices are regularly disconnected form the network. The phones lose connection with the internet and switch to data, sometimes they reconnect to the wifi with success, sometimes not. TV gets kicked from wifi and has to be reconnected manually every few days. Laptops and desktops lose internet connection for a few seconds at a time but stay connected to the wifi. Smartthings hub also regularly loses internet connection and sometimes disappears from the network, making it impossible to control the Zigbee devices at home for a few minutes until it reconnects.
I looked into my router logs and I saw that it keeps sending like 10-20 udhcp: sending renew or udhcp: sending discover (don’t remember exactly which one it was)  requests every 2-5 minutes. Maybe that has something to do with the issue? I can paste the logs as a comment when I get home.
  • 18 reacties
  • 10 december 2024
Here are the WAN-DHCP logs with a lot of repeating udhcp sending dicover messages.
1 Dec 10 11:32:53 daemon debug dhcpc udhcpc: Sending discover...
2 Dec 10 11:32:37 daemon debug dhcpc udhcpc: Sending discover...
3 Dec 10 11:32:29 daemon debug dhcpc udhcpc: Sending discover...
4 Dec 10 11:32:29 daemon info dhcpc udhcpc: dhcpMsgSend: msgType[-2147483403]
5 Dec 10 11:32:29 daemon info dhcpc udhcpc: Lease of IP_TWO obtained, lease time 1800
6 Dec 10 11:32:28 daemon debug dhcpc udhcpc: Sending renew...
7 Dec 10 11:32:25 daemon debug dhcpc udhcpc: Sending discover...
8 Dec 10 11:31:21 daemon debug dhcpc udhcpc: Sending discover...
9 Dec 10 11:30:17 daemon debug dhcpc udhcpc: Sending discover...
10 Dec 10 11:29:13 daemon debug dhcpc udhcpc: Sending discover...
11 Dec 10 11:28:09 daemon debug dhcpc udhcpc: Sending discover...
12 Dec 10 11:27:37 daemon debug dhcpc udhcpc: Sending discover...
13 Dec 10 11:27:21 daemon debug dhcpc udhcpc: Sending discover...
14 Dec 10 11:27:13 daemon debug dhcpc udhcpc: Sending discover...
15 Dec 10 11:27:12 daemon info dhcpc udhcpc: dhcpMsgSend: msgType[-2147483403]
16 Dec 10 11:27:12 daemon info dhcpc udhcpc: Lease of IP_ONE obtained, lease time 1800
17 Dec 10 11:27:12 daemon debug dhcpc udhcpc: Sending renew...
18 Dec 10 11:27:09 daemon debug dhcpc udhcpc: Sending discover...
19 Dec 10 11:26:04 daemon debug dhcpc udhcpc: Sending discover...
20 Dec 10 11:25:00 daemon debug dhcpc udhcpc: Sending discover...
There are also a lot of warnings in the “mesh” category, but these are new and likely not related to the issue, as the issue used to happen even before these mesh warnings showed up in the logs, including before I had the wifi extender installed.
  • 14875 reacties
  • 10 december 2024
Thanks for sharing ​@Lursmani9. Could you by any chance provide a MAC address of a device on which you are noticing the outage and then please provide a date/time of when the outage occurred? Then I can investigate a bit more. The only thing I have noticed is that the coverage of the modem itself is not that good and there is some congestion on the 2.4GHz frequency from time to time. Where exactly is the modem located?
  • 18 reacties
  • 10 december 2024
I will start logging again this evening and provide the MAC addresses of my computers.
The modem is located in the meterkast, while the wifi extender is located in the office on the floor above. The extender is connected to the modem using an ethernet cable. There is a thin brick wall between the modem and the laptop/PC. In addition, everything except the PC should be connected to the 5Ghz network as they have appropriate wifi radios, only one of the PCs is stuck on 2.4Ghz, as well as a wifi plug that I use for Christmas lights and an energy monitoring device from Aurum. The wifi plugs and the energy monitoring device were connected in the last month, but the issue has been happening since the very start of my subscription.
  • 18 reacties
  • 10 december 2024
I have made a log on my PC with the MAC being: E0-E1-A9-34-35-45
Here is the log:
As you can see, there are constant ping spikes, often up to and above 1000. This evening the internet was so bad that streaming go constantly interrupted, most likely due to these lag spikes.
I doubt this is caused by signal strength being low, since I have my work laptop in the office right next to the wifi extender, and that laptop also frequently loses connection to the internet.
  • 18 reacties
  • 10 december 2024
Just caught another outage at around 21:21:55. I exported the logs between 21:21 and 21:22, maybe there are some clues there.
Toon inhoud
341 Dec 10 21:22:18 user info mesh mesh: 1733862138 [ZSL] ======================================================
342 Dec 10 21:22:18 user notice mesh mesh: 1733862138 [ZSL] STA 50:8E:49:DC:ED:93, non-steerable.
343 Dec 10 21:22:18 user info mesh mesh: 1733862138 [ZSL] ======================================================
344 Dec 10 21:22:18 user notice mesh mesh: 1733862138 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979476
345 Dec 10 21:22:18 user notice mesh mesh: 1733862138 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979476
346 Dec 10 21:22:18 user notice mesh mesh: 1733862138 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979476
347 Dec 10 21:22:18 user notice mesh mesh: 1733862138 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979476
348 Dec 10 21:22:17 user notice mesh mesh: 1733862137 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979476
349 Dec 10 21:22:17 user notice mesh mesh: 1733862137 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979476
350 Dec 10 21:22:16 user warning mesh mesh: 1733862136 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
351 Dec 10 21:22:16 user notice mesh mesh: 1733862136 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b1a3
352 Dec 10 21:22:15 user warning mesh mesh: 1733862135 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
353 Dec 10 21:22:15 user notice mesh mesh: 1733862135 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 4595
354 Dec 10 21:22:15 user info mesh mesh: 1733862135 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
355 Dec 10 21:22:11 user notice mesh mesh: 1733862131 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979470
356 Dec 10 21:22:11 user notice mesh mesh: 1733862131 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979470
357 Dec 10 21:22:11 user notice mesh mesh: 1733862131 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979470
358 Dec 10 21:22:11 user notice mesh mesh: 1733862131 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b1a2 from 48:ed:e6:60:fd:7d
359 Dec 10 21:22:10 user notice mesh mesh: 1733862130 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP capability report msgId 4594 from 48:ed:e6:60:fd:7d
360 Dec 10 21:22:10 user info mesh mesh: 1733862130 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending AP capability Query msgId 4594 to 48:ed:e6:60:fd:7d
361 Dec 10 21:22:10 user info mesh mesh: 1733862130 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Vendor specific msgId 4593 to 48:ed:e6:60:fd:7d
362 Dec 10 21:22:10 user notice mesh mesh: 1733862130 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received topology response msgId 4591 from 48:ed:e6:60:fd:7d
363 Dec 10 21:22:10 user warning mesh mesh: 1733862130 [ZSL] Input radio mac is empty!!
364 Dec 10 21:22:10 user info mesh mesh: 1733862130 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Topology Query msgId 4591 to 48:ed:e6:60:fd:7d
365 Dec 10 21:22:08 user notice mesh mesh: 1733862128 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979466
366 Dec 10 21:22:08 user notice mesh mesh: 1733862128 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979466
367 Dec 10 21:22:08 user notice mesh mesh: 1733862128 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979466
368 Dec 10 21:22:07 user notice mesh mesh: 1733862127 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979466
369 Dec 10 21:22:07 user notice mesh mesh: 1733862127 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979466
370 Dec 10 21:22:07 user notice mesh mesh: 1733862127 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979466
371 Dec 10 21:22:07 user info mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 4590 to 48:ed:e6:60:fd:7d
372 Dec 10 21:22:07 user notice mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 4590 from 48:ed:e6:60:fd:7d
373 Dec 10 21:22:07 user info mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b1a1 to 48:ed:e6:60:fd:7d
374 Dec 10 21:22:07 user notice mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b1a1 from 48:ed:e6:60:fd:7d
375 Dec 10 21:22:07 user info mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 4590
376 Dec 10 21:22:07 user info mesh mesh: 1733862127 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 4590 to 48:ed:e6:60:fd:7d
377 Dec 10 21:22:06 user warning mesh mesh: 1733862126 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
378 Dec 10 21:22:06 user notice mesh mesh: 1733862126 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b1a0
379 Dec 10 21:22:05 user warning mesh mesh: 1733862125 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
380 Dec 10 21:22:05 user notice mesh mesh: 1733862125 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 458f
381 Dec 10 21:22:05 user info mesh mesh: 1733862125 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
382 Dec 10 21:22:03 user info mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 458e to 48:ed:e6:60:fd:7d
383 Dec 10 21:22:03 user notice mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 458e from 48:ed:e6:60:fd:7d
384 Dec 10 21:22:03 user info mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b19f to 48:ed:e6:60:fd:7d
385 Dec 10 21:22:03 user notice mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b19f from 48:ed:e6:60:fd:7d
386 Dec 10 21:22:03 user info mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 458e
387 Dec 10 21:22:03 user info mesh mesh: 1733862123 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 458e to 48:ed:e6:60:fd:7d
388 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979460
389 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979460
390 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending AP Capability Report msgId b19e to 48:ed:e6:60:fd:7d
391 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP capability query msgId b19e from 48:ed:e6:60:fd:7d
392 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [MSG] Device F8:0D:A9:2D:98:D9, send config response msgId b19c to 48:ED:E6:60:FD:7D
393 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Topology Response msgId b19b to 48:ed:e6:60:fd:7d
394 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = rax5, mdid = bead
395 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax3, mdid = 3333
396 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax2, mdid = 2222
397 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax1, mdid = 1111
398 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = rax0, mdid = 0
399 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = ra3, mdid = 3333
400 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = ra2, mdid = 2222
401 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = ra1, mdid = 1111
402 Dec 10 21:22:01 user info mesh mesh: 1733862121 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = ra0, mdid = 0
403 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received topology query msgId b19b from 48:ed:e6:60:fd:7d
404 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979460
405 Dec 10 21:22:01 user notice mesh mesh: 1733862121 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b19a from 48:ed:e6:60:fd:7d
406 Dec 10 21:21:59 user info mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 458d to 48:ed:e6:60:fd:7d
407 Dec 10 21:21:59 user notice mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 458d from 48:ed:e6:60:fd:7d
408 Dec 10 21:21:59 user info mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b199 to 48:ed:e6:60:fd:7d
409 Dec 10 21:21:59 user notice mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b199 from 48:ed:e6:60:fd:7d
410 Dec 10 21:21:59 user info mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 458d
411 Dec 10 21:21:59 user info mesh mesh: 1733862119 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 458d to 48:ed:e6:60:fd:7d
412 Dec 10 21:21:58 user notice mesh mesh: 1733862118 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979456
413 Dec 10 21:21:58 user notice mesh mesh: 1733862118 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979456
414 Dec 10 21:21:57 user notice mesh mesh: 1733862117 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979456
415 Dec 10 21:21:57 user notice mesh mesh: 1733862117 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979456
416 Dec 10 21:21:57 user notice mesh mesh: 1733862117 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979456
417 Dec 10 21:21:57 user notice mesh mesh: 1733862117 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979456
418 Dec 10 21:21:56 user warning mesh mesh: 1733862116 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
419 Dec 10 21:21:56 user notice mesh mesh: 1733862116 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b198
420 Dec 10 21:21:56 user info mesh mesh: 1733862116 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 458b
421 Dec 10 21:21:56 user info mesh mesh: 1733862116 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Link Metric Query msgId 458c to 48:ed:e6:60:fd:7d
422 Dec 10 21:21:56 user info mesh mesh: 1733862116 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Combined Infrastructure Metrics msgId 458b to 48:ed:e6:60:fd:7d
423 Dec 10 21:21:55 user warning mesh mesh: 1733862115 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
424 Dec 10 21:21:55 user notice mesh mesh: 1733862115 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 458a
425 Dec 10 21:21:55 user info mesh mesh: 1733862115 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
426 Dec 10 21:21:51 user notice mesh mesh: 1733862111 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979450
427 Dec 10 21:21:51 user notice mesh mesh: 1733862111 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979450
428 Dec 10 21:21:51 user notice mesh mesh: 1733862111 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979450
429 Dec 10 21:21:51 user notice mesh mesh: 1733862111 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b197 from 48:ed:e6:60:fd:7d
430 Dec 10 21:21:47 user notice mesh mesh: 1733862107 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979446
431 Dec 10 21:21:47 user notice mesh mesh: 1733862107 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979446
432 Dec 10 21:21:47 user notice mesh mesh: 1733862107 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979446
433 Dec 10 21:21:47 user notice mesh mesh: 1733862107 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979446
434 Dec 10 21:21:47 user notice mesh mesh: 1733862107 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979446
435 Dec 10 21:21:46 user notice mesh mesh: 1733862106 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979446
436 Dec 10 21:21:46 user warning mesh mesh: 1733862106 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
437 Dec 10 21:21:46 user notice mesh mesh: 1733862106 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b196
438 Dec 10 21:21:45 user notice mesh mesh: 1733862105 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP capability report msgId 4588 from 48:ed:e6:60:fd:7d
439 Dec 10 21:21:45 user info mesh mesh: 1733862105 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending AP capability Query msgId 4588 to 48:ed:e6:60:fd:7d
440 Dec 10 21:21:45 user info mesh mesh: 1733862105 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Vendor specific msgId 4587 to 48:ed:e6:60:fd:7d
441 Dec 10 21:21:45 user notice mesh mesh: 1733862105 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received topology response msgId 4585 from 48:ed:e6:60:fd:7d
442 Dec 10 21:21:45 user warning mesh mesh: 1733862105 [ZSL] Input radio mac is empty!!
443 Dec 10 21:21:45 user info mesh mesh: 1733862105 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Topology Query msgId 4585 to 48:ed:e6:60:fd:7d
444 Dec 10 21:21:45 user warning mesh mesh: 1733862105 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
445 Dec 10 21:21:45 user notice mesh mesh: 1733862105 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 4584
446 Dec 10 21:21:45 user info mesh mesh: 1733862105 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
447 Dec 10 21:21:43 user info mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 4583 to 48:ed:e6:60:fd:7d
448 Dec 10 21:21:43 user notice mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 4583 from 48:ed:e6:60:fd:7d
449 Dec 10 21:21:43 user info mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b195 to 48:ed:e6:60:fd:7d
450 Dec 10 21:21:43 user notice mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b195 from 48:ed:e6:60:fd:7d
451 Dec 10 21:21:43 user info mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 4583
452 Dec 10 21:21:43 user info mesh mesh: 1733862103 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 4583 to 48:ed:e6:60:fd:7d
453 Dec 10 21:21:41 user notice mesh mesh: 1733862101 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979440
454 Dec 10 21:21:41 user notice mesh mesh: 1733862101 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979440
455 Dec 10 21:21:41 user notice mesh mesh: 1733862101 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979440
456 Dec 10 21:21:41 user notice mesh mesh: 1733862101 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b194 from 48:ed:e6:60:fd:7d
457 Dec 10 21:21:39 user info mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 4582 to 48:ed:e6:60:fd:7d
458 Dec 10 21:21:39 user notice mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 4582 from 48:ed:e6:60:fd:7d
459 Dec 10 21:21:39 user info mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b193 to 48:ed:e6:60:fd:7d
460 Dec 10 21:21:39 user notice mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b193 from 48:ed:e6:60:fd:7d
461 Dec 10 21:21:39 user info mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 4582
462 Dec 10 21:21:39 user info mesh mesh: 1733862099 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 4582 to 48:ed:e6:60:fd:7d
463 Dec 10 21:21:37 user notice mesh mesh: 1733862097 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979435
464 Dec 10 21:21:37 user notice mesh mesh: 1733862097 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979435
465 Dec 10 21:21:37 user notice mesh mesh: 1733862097 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979435
466 Dec 10 21:21:37 user notice mesh mesh: 1733862097 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979435
467 Dec 10 21:21:36 user notice mesh mesh: 1733862096 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979435
468 Dec 10 21:21:36 user notice mesh mesh: 1733862096 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979435
469 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending AP Capability Report msgId b192 to 48:ed:e6:60:fd:7d
470 Dec 10 21:21:36 user notice mesh mesh: 1733862096 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP capability query msgId b192 from 48:ed:e6:60:fd:7d
471 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [MSG] Device F8:0D:A9:2D:98:D9, send config response msgId b190 to 48:ED:E6:60:FD:7D
472 Dec 10 21:21:36 user warning mesh mesh: 1733862096 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
473 Dec 10 21:21:36 user notice mesh mesh: 1733862096 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b18f
474 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Topology Response msgId b18e to 48:ed:e6:60:fd:7d
475 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = rax5, mdid = bead
476 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax3, mdid = 3333
477 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax2, mdid = 2222
478 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = rax1, mdid = 1111
479 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = rax0, mdid = 0
480 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = ra3, mdid = 3333
481 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, disabled ifnames = ra2, mdid = 2222
482 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = ra1, mdid = 1111
483 Dec 10 21:21:36 user info mesh mesh: 1733862096 [1905] [TLV] Device F8:0D:A9:2D:98:D9, insert MDID TLV, enabled ifnames = ra0, mdid = 0
484 Dec 10 21:21:36 user notice mesh mesh: 1733862096 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received topology query msgId b18e from 48:ed:e6:60:fd:7d
485 Dec 10 21:21:35 user warning mesh mesh: 1733862095 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
486 Dec 10 21:21:35 user notice mesh mesh: 1733862095 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 4581
487 Dec 10 21:21:35 user info mesh mesh: 1733862095 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
488 Dec 10 21:21:31 user notice mesh mesh: 1733862091 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979430
489 Dec 10 21:21:31 user notice mesh mesh: 1733862091 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979430
490 Dec 10 21:21:31 user notice mesh mesh: 1733862091 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979430
491 Dec 10 21:21:31 user notice mesh mesh: 1733862091 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b18c from 48:ed:e6:60:fd:7d
492 Dec 10 21:21:27 user notice mesh mesh: 1733862087 [ZSL] STA 1C:90:FF:E0:40:29, change from invalid to valid, timestamp=1979425
493 Dec 10 21:21:27 user notice mesh mesh: 1733862087 [ZSL] STA BA:85:D4:D2:AD:9C, change from invalid to valid, timestamp=1979425
494 Dec 10 21:21:27 user notice mesh mesh: 1733862087 [ZSL] STA E0:E1:A9:34:35:45, change from invalid to valid, timestamp=1979425
495 Dec 10 21:21:26 user notice mesh mesh: 1733862086 [ZSL] STA 16:BB:57:F8:FE:A7, change from invalid to valid, timestamp=1979425
496 Dec 10 21:21:26 user notice mesh mesh: 1733862086 [ZSL] STA 40:D6:3C:94:07:99, change from invalid to valid, timestamp=1979425
497 Dec 10 21:21:26 user warning mesh mesh: 1733862086 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
498 Dec 10 21:21:26 user notice mesh mesh: 1733862086 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId b18b
499 Dec 10 21:21:26 user notice mesh mesh: 1733862086 [ZSL] STA 50:8E:49:DC:ED:93, change from invalid to valid, timestamp=1979425
500 Dec 10 21:21:25 user info mesh mesh: 1733862085 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Link Metric Query msgId 4580 to 48:ed:e6:60:fd:7d
501 Dec 10 21:21:25 user warning mesh mesh: 1733862085 [1905] Device f8:0d:a9:2d:98:d9, unknown option type 0 to get 1905 datamoddel
502 Dec 10 21:21:25 user notice mesh mesh: 1733862085 [1905] [MSG] Device F8:0D:A9:2D:98:D9, received VEND_MSG_TYPE_WIFI_CLIENT_MCAST2 msgId 457f
503 Dec 10 21:21:25 user info mesh mesh: 1733862085 [1905] Device F8:0D:A9:2D:98:D9, WiFi NBR device count = 7
504 Dec 10 21:21:23 daemon debug dhcpc udhcpc: Sending discover...
505 Dec 10 21:21:23 user info mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 457e to 48:ed:e6:60:fd:7d
506 Dec 10 21:21:23 user notice mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 457e from 48:ed:e6:60:fd:7d
507 Dec 10 21:21:23 user info mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b18a to 48:ed:e6:60:fd:7d
508 Dec 10 21:21:23 user notice mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b18a from 48:ed:e6:60:fd:7d
509 Dec 10 21:21:23 user info mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 457e
510 Dec 10 21:21:23 user info mesh mesh: 1733862083 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 457e to 48:ed:e6:60:fd:7d
511 Dec 10 21:21:21 user notice mesh mesh: 1733862081 [ZSL] STA 5C:E9:1E:B9:34:38, change from invalid to valid, timestamp=1979420
512 Dec 10 21:21:21 user notice mesh mesh: 1733862081 [ZSL] STA 28:6D:97:CD:E3:D9, change from invalid to valid, timestamp=1979420
513 Dec 10 21:21:21 user notice mesh mesh: 1733862081 [ZSL] STA 4C:82:A9:B3:1F:7B, change from invalid to valid, timestamp=1979420
514 Dec 10 21:21:21 user notice mesh mesh: 1733862081 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP metric response msgId b189 from 48:ed:e6:60:fd:7d
515 Dec 10 21:21:20 user notice mesh mesh: 1733862080 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received AP capability report msgId 457d from 48:ed:e6:60:fd:7d
516 Dec 10 21:21:20 user info mesh mesh: 1733862080 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending AP capability Query msgId 457d to 48:ed:e6:60:fd:7d
517 Dec 10 21:21:20 user info mesh mesh: 1733862080 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Vendor specific msgId 457c to 48:ed:e6:60:fd:7d
518 Dec 10 21:21:20 user notice mesh mesh: 1733862080 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received topology response msgId 457a from 48:ed:e6:60:fd:7d
519 Dec 10 21:21:20 user warning mesh mesh: 1733862080 [ZSL] Input radio mac is empty!!
520 Dec 10 21:21:20 user info mesh mesh: 1733862080 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending Topology Query msgId 457a to 48:ed:e6:60:fd:7d
521 Dec 10 21:21:19 user info mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId 4579 to 48:ed:e6:60:fd:7d
522 Dec 10 21:21:19 user notice mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId 4579 from 48:ed:e6:60:fd:7d
523 Dec 10 21:21:19 user info mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending 1905 Ack msgId b188 to 48:ed:e6:60:fd:7d
524 Dec 10 21:21:19 user notice mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received UnAssociated STA link metric response msgId b188 from 48:ed:e6:60:fd:7d
525 Dec 10 21:21:19 user info mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, received 1905 Ack msgId 4579
526 Dec 10 21:21:19 user info mesh mesh: 1733862079 [1905] [MSG] Device f8:0d:a9:2d:98:d9, sending UnAssociated Staion Link Metrics Query msgId 4579 to 48:ed:e6:60:fd:7d
527 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid phytype value 0
528 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid mcs value 0, set with default value
529 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid mcs value 0, set with default value
530 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid phytype value 0
531 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid mcs value 0, set with default value
532 Dec 10 21:21:18 user err mesh mesh: 1733862078 [ZSL] invalid mcs value 0, set with default value
533 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA FC:67:1F:3F:32:D0, invalid station status
534 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
535 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA FC:67:1F:27:CE:3F, invalid station status
536 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
537 Dec 10 21:21:17 user warning mesh mesh: 1733862077 [ZSL] STA 1C:90:FF:E0:40:29, not support 11v.
538 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
539 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 18:56:80:6A:6D:82, invalid station status
540 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
541 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 28:11:A8:49:F5:E8, invalid station status
542 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
543 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA BA:85:D4:D2:AD:9C, not a suffering STA
544 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] STA BA:85:D4:D2:AD:9C, Rate=650/866, (24.50.866)
545 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] STA BA:85:D4:D2:AD:9C, RADIO F8:0D:A9:2D:98:DA, estimate RSSI=-65
546 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
547 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 96:68:32:5E:7A:DE, invalid station status
548 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
549 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 14:13:33:B8:62:0F, invalid station status
550 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
551 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 5A:42:C9:13:74:A6, invalid station status
552 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
553 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, can't find target BSS
554 Dec 10 21:21:17 user err mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, BSS 48:ED:E6:60:FD:7E, no RCPI monitor result on BSS
555 Dec 10 21:21:17 user err mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, BSS 48:ED:E6:60:FD:7F, no RCPI monitor result on BSS
556 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, RSSI=-69, Rate=65/300 (50.78), Hops=0, to BSS F8:0D:A9:2D:98:DB, RSSI=-75, Rate=1000/650, Hops=0, TargetRate=4 (6.120.26.87.31.93.45)
557 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, Rate=65/300, (90.50.650)
558 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] STA E0:E1:A9:34:35:45, RADIO F8:0D:A9:2D:98:DB, estimate RSSI=-75
559 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
560 Dec 10 21:21:17 user notice mesh mesh: 1733862077 [ZSL] STA 36:4D:5A:5B:BA:AF, invalid station status
561 Dec 10 21:21:17 user info mesh mesh: 1733862077 [ZSL] ======================================================
  • 18 reacties
  • 10 december 2024
And here is proof that a powerflip has no effect. The wide red column here is the powerflip, and as visible, network issues continue as before.
  • 14875 reacties
  • 12 december 2024
It seems to only happen in the evenings after your tests, do you get it during the day or not at all ​@Lursmani9?
  • 18 reacties
  • 12 december 2024
@Tommie van Odido It happens during all times of day, but I can only log it in the evenings since I work during the day. In the screenshop in the OP we can see that some outages are in the morning or the afternoon. I could also log it tomorrow during the whole day, but I see no point as the first screenshot already shows that it happens at all times.
It does vary from day to day, some days the outages are less frequent, while the day before yesterday my internet was almost unusable.
  • 14875 reacties
  • 13 december 2024
We have opened a ticket, we are indeed seeing some packet loss back with several customers on Delta ​@Lursmani9. We suspect this is the cause for you as well. Hopefully they can investigate this soon!
  • 18 reacties
  • 13 december 2024
Sounds great, ​@Tommie van Odido. Is there anywhere I can follow the status of this issue?
Ishana van Odido
  • 2444 reacties
  • 14 december 2024
Hi ​@Lursmani9, no worries! You will be kept informed by email or by us. Have a nice weekend! Greetings, Ishana
  • 18 reacties
  • 3 februari 2025
Hey ​@Ishana van Odido, is there an update on this issue?
  • 14875 reacties
  • 4 februari 2025
Hey ​@Lursmani9, they have cleaned the fibers of the switch in the Pop. It should be better right now, if not, please let me know!
  • 18 reacties
  • 7 februari 2025
Hey Tommie,
I do notice that the network outages are a little less frequent, but they still occur several times a day. So sadly it's not fully fixed yet. My tv and smart hub are regularly without internet connection and have to be reconnected almost daily. And I still get huge lag spikes when gaming.
Ishana van Odido
  • 2444 reacties
  • 8 februari 2025
Hi ​@Lursmani9, good that you indicate this! I would really like to investigate this further for you. Do you notice that it occurs more often at certain times or does this really differ per day? I am also curious whether you notice a change in the problem compared to before. Then I will pass it on! Greetings, Ishana
  • 18 reacties
  • 11 februari 2025
I haven't noticed a pattern, it happens randomly throughout the day. It even happens overnight sometimes, when no one in the house is using the internet (I notice this when in the morning my phone is connected to the guest network because  the main network lost connection overnight. Also my smart hub says that it lost connection).
It does happen less frequently than since I first posted, but it's still a daily occurrence.
  • 14875 reacties
  • 12 februari 2025
I went to check for you ​@Lursmani9, but I see that there was no break on the 11th.
However, I see that your phone switched to the wifi point in the morning. Can you list all the clients you have connected to your network? I can see that some of them are overloading the 2.4GHz band. This can cause 'dropped services', but this is caused by a jammer on your network. The internet coming from the fibre is simply stable and does not drop out.
If you experience this again, could you please send me the date, time and MAC address? Then I can do a more targeted search!
  • 18 reacties
  • 12 februari 2025
I can list the data you're asking, but I'm certain this isn't a wifi issue. Odido didn't detect issues with the network before either.
This is an issue with the fiber connection. Since this problem started I've wired my commonly used stationary devices via ethernet but this issue happens on those devices too.
In addition, my phone and all my wireless devices use 5ghz, except 2 wifi smart plugs, a wifi camera and a Energyflip device from Aurum Europe. Signal strength is excellent for all devices except one wifi plug, they're all practically next to the modem/wifi extender.
I can make another log using my ethernet-wired computer.
  • 18 reacties
  • 13 februari 2025
Started logging today after work. I am logging on a windows computer that is connected to the modem via ethernet. I have detected two instances of network outages so far, at 21:54 and 22:34.
Here are the logs at around those timestamps.
22:34
Toon inhoud
32
Feb 13 22:40:41
daemon
info
dhcpc
33
Feb 13 22:40:41
daemon
info
dhcpc
udhcpc: Lease of 10.139.38.39 obtained, lease time 1800
34
Feb 13 22:40:41
daemon
debug
dhcpc
35
Feb 13 22:40:36
daemon
debug
dhcpc
36
Feb 13 22:40:04
daemon
debug
dhcpc
37
Feb 13 22:39:48
daemon
debug
dhcpc
38
Feb 13 22:39:40
daemon
debug
dhcpc
39
Feb 13 22:39:36
daemon
debug
dhcpc
40
Feb 13 22:38:32
daemon
debug
dhcpc
41
Feb 13 22:37:28
daemon
debug
dhcpc
42
Feb 13 22:36:53
daemon
info
dhcpc
43
Feb 13 22:36:53
daemon
info
dhcpc
udhcpc: Lease of 85.144.163.220 obtained, lease time 1800
44
Feb 13 22:36:53
daemon
debug
dhcpc
45
Feb 13 22:36:23
daemon
debug
dhcpc
46
Feb 13 22:35:19
daemon
debug
dhcpc
47
Feb 13 22:34:47
daemon
debug
dhcpc
48
Feb 13 22:34:31
daemon
debug
dhcpc
49
Feb 13 22:34:23
daemon
debug
dhcpc
50
Feb 13 22:34:19
daemon
debug
dhcpc
51
Feb 13 22:33:15
daemon
debug
dhcpc
52
Feb 13 22:32:10
daemon
debug
dhcpc
53
Feb 13 22:31:06
daemon
debug
dhcpc
54
Feb 13 22:30:44
daemon
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1
55
Feb 13 22:30:44
daemon
debug
dhcpd
dnsmasq-dhcp: ip lease:192.168.1.80, given to MAC:50:8e:49:dc:ed:93, with hostname:*, Lease time:1169596
56
Feb 13 22:30:44
daemon
info
dhcpd
57
Feb 13 22:30:02
daemon
debug
dhcpc
58
Feb 13 22:29:53
daemon
debug
dhcpd
59
Feb 13 22:29:53
daemon
debug
dhcpd
dnsmasq-dhcp: ip lease:192.168.1.80, given to MAC:50:8e:49:dc:ed:93, with hostname:*, Lease time:1169545
60
Feb 13 22:29:53
daemon
info
dhcpd
21:54
Toon inhoud
133
Feb 13 21:57:22
daemon
debug
dhcpc
134
Feb 13 21:56:18
daemon
debug
dhcpc
135
Feb 13 21:55:38
daemon
info
dhcpc
136
Feb 13 21:55:38
daemon
info
dhcpc
137
Feb 13 21:55:38
daemon
debug
dhcpc
138
Feb 13 21:55:14
daemon
debug
dhcpc
139
Feb 13 21:54:10
daemon
debug
dhcpc
140
Feb 13 21:53:06
daemon
debug
dhcpc
141
Feb 13 21:52:33
daemon
debug
dhcpc
142
Feb 13 21:52:18
daemon
debug
dhcpc
143
Feb 13 21:52:10
daemon
debug
dhcpc
144
Feb 13 21:52:06
daemon
debug
dhcpc
145
Feb 13 21:51:50
daemon
info
dhcpc
146
Feb 13 21:51:50
daemon
info
dhcpc
147
Feb 13 21:51:50
daemon
debug
dhcpc
148
Feb 13 21:51:02
daemon
debug
dhcpc
  • 14875 reacties
  • 14 februari 2025
Thanks ​@Lursmani9, can you check in with me on monday? I would like to start our own logging on your modem but the right guy for this job is not at work at the moment.
  • 18 reacties
  • 17 februari 2025
Hey ​@Tommie van Odido. I'll be available tomorrow all day if I can be of help.
  • 11 reacties
  • 18 februari 2025
Same issue here! It’s really annoying since it’s not consistent as well. I’ve tried restarting the modem and it didn’t help.
  • 14875 reacties
  • 19 februari 2025
Hi ​@Lursmani9, the person who can enable logging is still a week away, could you send me a reminder in the topic next Monday?
Hey ​@BEEMOO, welcome to our Community!
I would also like to check with you, could you please add your postcode, house number, date of birth and the last four digits of your bank account number to your profile? Then I can check with you.
