After crossing the border, odido just stopped working and really let me down. I had to ask people to give me the Internet and buy an online SIM card from another provider that worked great. I see a lot of feedback from clients on this forum, where people face the same problem as me, because their roaming is blocked just like that. Is it time to do something about it?
And please change the block from me.
Beste antwoord door Taninator
Marciano van Odido schreef:
Good afternoon Taninator, and welcome to our Community! I hope you're enjoying your time abroad. There was indeed a barring on International roaming on your account. In your case it's because your subscription started under 3 months ago. There's always a barring at the start of the subscription. I just removed it for you. Please let me know if you're able to connect to networks abroad! 😄
I have already returned to the Netherlands, thanks a lot for your help!
Do you perhaps have a open invoice or a betalingsregeling which is blocking use outside NL?
Otherwise try manually selecting another network provider and make sure mobile data and roaming are turned on.
Hello. I do not have an open invoice or beta version, manually selecting an operator does not help, the network does not appear. I read that many people face this problem, that the operator blocks the use of roaming, though. I have Data enabled on the territory of the European Union
Good morning Taninator, you're welcome! You should be able to connect to networks during your next stay abroad. I'd love to hear your confirmation in the future. For now, I wish you a great day, and if you have any other questions, please feel free to start a new topic. The Community is here for you!
Hi, I have a similar problem. I signed a new contract, got a new phone and some time ago I noticed that my 5g disappears and it keeps hanging on "E" and does not switch to 4G/5G after crossing the border with Belgium. Turning the phone off and on helps. I often go to Belgium and I do not want to reset the phone every time. Please help.
Hi ​@Tomaszkk, welcome to our Community! And nice to see that you're staying with us with your new contract. I've looked into your account, and I see that your current subscription is still running until the 30th of March, so the good news is that your new/current subscription isn't causing this issue. Going to Belgium often sounds good. And I understand you need to be connected at all times and not only after turning your phone off and on. If you turn your phone off and on, do you have a stable 4G/5G connection afterwards? If yes, it sounds like an issue with your phone/network settings or being connected to a network that doesn't have a good network. Let's look at a few things you can do to fix this and help me get more clarity on the situation:
You can reset your network settings while in Belgium. This resets everything, so it's possible this fixes all future automatic connections in Belgium
You can check which network you are connecting to automatically, and test if another network has a better connection. You can connect to Orange, Proximus and Telenet Group
Please fill in your zip code, house number and the last 4 digits of your IBAN in your profile.
I'm happy to check if I can see anything else! 😊
Bestand scannen voor virussen
We maken gebruik van 3 verschillende soorten cookies. Je kunt kiezen welke cookies je wilt accepteren. We hebben basiscookies nodig om deze site te laten werken, daarom moet je ten minste deze selecteren. Meer informatie.
