Problems with SIM activation
  • 21 september 2024
  • 196 Bekeken
Hi,
On Friday I picked up my iPhone 16 Plus from the Odido Store and I tried to transfer my data from my old iPhone. I had an eSIM on my old iPhone and I asked the representative at the shop if I need to get a new eSIM since I knew that those are attached to the phone and he assured me that the eSIM can be moved while migrating. I migrated my data after I got home and the SIM was moved as well. But unfortunately I got an error that the SIM could not be activated and I should contact Odido. I tried to order a new eSIM in the Odido app, thinking that something went wrong with the transfer but still nothing. In the end I went back to the store and we tried a couple more SIMs and eSIMs but none worked. I noticed in the evening that in the Odido app the ICC number didn’t correspond to any SIM I tried that day so I tried to reach Customer Support on X. They didn’t reply after 30 mins so I borrowed a phone from a friend to call Customer Service. I sent via email the passport image and still no luck. The team on X replied meanwhile  and I gave them the same info and they tried too, but no luck. I went to the Store in my town again today and we tried an eSIM and a normal SIM too but no luck again.  So at the moment I don’t really know who to contact and how to solve the situation. I tried to use a physical SIM from another provider to double check that the new phone is not broken and the network got picked up right away.
Thanks!
24 september 2024
Hi @mihai98924, super nice that you ordered the new iPhone 16 Plus from us. I hope you are happy with it! Of course, we are going to do everything we can to make sure you are back in touch as soon as possible. In the meantime, I see that you have been in contact with my colleague Anouk via X about an temporary solution. Good to see! Meanwhile, our technical colleagues are doing their best to ensure that you can use your subscription again as soon as possible. Our sincere apologies for the inconvenience!
Sam van Odido
Forum|alt.badge.img+7
  • Moderator | Mobiel
  • 24 september 2024
