Wifi is dropping
  • 24 February 2023
  • 9 reacties
  • 63 Bekeken
Since 3 days my wifi is dropping for every 5 minutes.
I did poweroff couple of times but not helpful
Waqqas 6 maanden geleden
@syerra
Can you remove all other devices which are connected with a wire to the modem and check the WiFi then?
Which modem do you have?
9 reacties
Hi @syerra welcome to our community! I would of course like you to enjoy a stable connection again as fast as possible. I have immediately checked it out. It looks like you're crossed in your network. I have therefore forwarded this to our technical department. They will look into it and hopefully it will be resolved soon!
Hi Team,
Still i have issues with wifi dropping.
Badge +14
Hello @syerra
Do you have a Fiber or DSL connection and is the wired connection also dropping every 5 minutes or is it stable?
DSL.
Wired connection is fine.
Wireless is not working properly.
Tried all the options (reset , poweroff ) but no use.
Badge +14
@syerra
Yes I did .
Zyxel T-54.
still wifi is dropping
Hi @syerra, I have yet to get a new update from our technicians. As soon as I know more, you will be contacted.
Its been a week almost ,my problem is not solved.
Its hampering my work.
I hope you will resolve it soon
Badge +14
@syerra
 If you have a WiFi repeater, switch off the Zyxel WiFi and check the WiFi of the repeater?
