internet installaion issues- not working
Hi, I have been trying to install the new modem since yesterday. However, even after trying all trial and error, Internet and DSL lights are not turning on.
I have tried to follow the instructions provided in guide. Basis that I have connected the 4 pin plug to wall socket as above.
i was using the same socket previously for the internet connection and it was working fine. So do not think it is a wiring issue. Request you to kindly help me or send a technician for help.
Beste antwoord door Brian
Hi @Vishnu Prasad I’ve checked your connection and it should have been active since last friday but something seems to have gone wrong on the network end and the connection hasn’t been activated. We are currently waiting on word from the grid operator that the connection is active. Apologies for the delay!
24 reacties
  • 21968 reacties
  • 10 oktober 2020
Hello @Vishnu Prasad
Can you unscrew the socket on photo 2 and make a picture of the wiring?
  • 13 reacties
  • 10 oktober 2020
Please find below the wiring pics
please let me know if this is sufficient
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
I don't think it is wired correctly can you take the socket out and show all wires?
Also can you try first to just remove the red wires right above and right under?
  • 13 reacties
  • 10 oktober 2020
I will try to open and share a pic but it seems difficult due to my limited tool access.
just wanted to point out that this socket was perfectly working till yesterday morning with TEL E2 modem. So I am not sure if there could be  any wiring issue.
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
Just try to take out the red wire for now right above and right under.
Let us know if it works or not.
  • 13 reacties
  • 10 oktober 2020
When you say take out, you mean disconnect it and keep it hanging?
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
Yeah disconnect it above and under, it should be 1 wire from above to under. You can remove it if 1 wire.
Jempi
  • 169 reacties
  • 10 oktober 2020
Dit heb toch niks met 4G voor thuis te maken? verkeerde topic toch?
  • 21968 reacties
  • 10 oktober 2020
Geplaatst in verkeerde sub forum...
  • 13 reacties
  • 10 oktober 2020
Indeed it was a single wire. Now they are not connected.  I removed it as below
Can you tell me the next step
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
You can take the red wire out, no need to leave it there, but is your modem now working or not?
  • 13 reacties
  • 10 oktober 2020
No. Still not working. The status did not change even now. Both internet and DSL lights are still off.
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
There are 2 possible combinations, sometimes the signal is on the other combination of 2 wires but for that you'll need to remove the socket so all wires are visible..
  • 13 reacties
  • 10 oktober 2020
I will try one again to open the socket.
Can you send a technician who would have expertise in this??
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
I'm a customer like you who was trying to help 🙂
It's weekend so you may get a reply from a moderator a bit later but they can arrange a technician for you.
You have now 2 black wires connected which were working according to you.
Looking at the wires closely the combinations should be black & transparent and white & transparent.
Both combinations are twisted.
  • 13 reacties
  • 10 oktober 2020
Ok. Thanks a lot. Hope moderator replies soon
  • 13 reacties
  • 10 oktober 2020
@Waqqas Does this help?
  • 13 reacties
  • 10 oktober 2020
Are these the white and transparent wires you are referring to?
And you suggest to disconnect one of the black wire and use transparent instead?
but which black connection out of 2?the one where red wire was connected or the sole one which was alone.
  • 21968 reacties
  • 10 oktober 2020
@Vishnu Prasad
It's all mixed up and since there are more white and black wires it's difficult to tell.
  • 13 reacties
  • 10 oktober 2020
@Waqqas thanks. Hope will have to wait for the moderator to help me
  • 6076 reacties
  • 12 oktober 2020
  • 13 reacties
  • 12 oktober 2020
Can you please give me a tentative date when it will be fine? I am without internet since last 4 days and it is very difficult in this time
  • 13 reacties
  • 13 oktober 2020
@Brian can I have some update on the issue. Almost 6 days since issue started
Forum|alt.badge.img+16
  • Community Manager
  • 10785 reacties
  • 14 oktober 2020
Hi @Vishnu Prasad, sorry to have kept you waiting a tad longer! I see my colleague has helped you schedule an appointment this afternoon. Hope all goes well, if there's anything I can do to help, please don't hesitate to ask.
Good luck and stay safe!
