Installation pending for unknown reason
  • August 1, 2023
  • 39 Bekeken
Hi,
Could you advise when can the installation happen ? I called customer service last week and they created the reference number 64786581 for setting up the work order but nothing moved out.
Previously with Ziggo, its just a plug and play to get the Internet running. I just checked the low monthly cost and immediately subscribed to T-mobile but its not working as expected with the installation process. Its nearly 2 months am using the mobile data. I think it would be beneficial if i had the T-mobile sim to use free internet vouchers unfortunately i dont have it.
Please let me know if you can help?
August 1, 2023
Hi @Chells, welcome to our Community!
Good that you are sounding the alarm for this. I went to check right away and I see that our mechanic was unable to enter the district exchange. There is a ticket open for you and it is still being processed. I assume you will be contacted as soon as possible to schedule a new appointment!
Forum|alt.badge.img+11
  • August 1, 2023
  • August 4, 2023
Hi Tommie,
Do you have any update on this ? Nobody contacted till now. Also, could you please let me know if i have the option to change to other providers and cancel the current service.
As i see i can cancel the services until the time the services becomes active. Its been a month since June 26th without the internet.
  • August 4, 2023
Hey @Chells, the ticket was forwarded to the right department two days ago. You can indeed still cancel your subscription if you would like.
