sorry for writing in English, my Dutch is not yet so advanced to discuss technical questions :D
Is it possible to use Draytek 2132fvn as a network switch / hub?
I have Fritzbox 5490 (fiber router) and 1750Es as repeaters and Draytek is no longer needed as a router, but I want to use it as a network switch.
In theory I should turn off DHCP server OFF on Draytek, then connect both routers via LAN cable and that’s basically it, but it doesn’t work. I spent several playing with Draytek’s setting, but no luck. Can’t even ping Fritzbox from Draytek’s menu.
Any ideas?
