No WiFi or LAN Connection
  • June 2, 2017
  • 383 Bekeken
Hi,
I don't have any WiFi or LAN connection at all and this has been the case for 2 days now.
My router is a DrayTek 2131FVn and I have a fibre optic connection.
I've tried the following:
- Factory resetting the router
- Replacing the fibre optic cable with a spare
- Unplugging the power supply and reconnecting it
I've tried connecting a LAN cable to all of the ports but I can't connect to it. It doesn't seem to recognise that there's anything connected (My Network preferences show that no connection is present)
Some observations on the only lights that are currently on:
- The lights on the LAN ports are flicking between 1 and 2, but not 3 or 4
- The ACT, USB1 and USB2 lights are constantly on
Any help would be greatly appreciated!
Thanks,
Sean
Beste antwoord door Pieter_B
Hello Tatsuken.
If nothing is connected to this USB ports, it is very strange that they light up.
You could try a factory reset as mentioned in this topic: https://forum.t-mobile.nl/t-mobile-thuis-internet-492/factory-reset-modem-276067
Otherwise i recommend you to call the service desk of T-Mobile, because your modem is probably defect.
1 reactie
Pieter_B
  • June 3, 2017
Hello Tatsuken.
