Hello, i got my router with DSL connection but I only have it in the wall (COAX )
Hello
Could you look for any of these in your fusebox, livingroom or somewhere else?
There could also be just a telephone cable which can be used.
Hello
Dear, no there is only one i just post, the question is will the internet work with a converter or something or i just cancel my contract?
Since you were able to suscribe to a DSL subscription there should be an ISRA In your home, maybe it needs to be repaired?
Once your subscription starts a moderator could send a technician to find the ISRA.
The COAX connection cannot be used for DSL
Dear, I think my subscription started today. Could you send me someone on Monday because I am in a bit of hurry thanks.
I'm not a moderator, please wait for them to reply, you can check the installation date in your T-Mobile thuis account
Ok Thanks
Hi
I wanted to help you further as soon as possible by taking a look into your profile. I see that one of my colleagues has already sent a request to our technical department to fix this for you. It always takes a few days before the technical department successfully closes the request, but we're working on it. My colleague will keep you posted!
Hi
Dear Lisa,
Thanks a lot for your help, but is there any way we can fast up the prosses because I need internet for my work.
Regards
Mohamed Afkar
Hi
Dear Lisa,
Regards
Mohamed Afkar
Good Moring, if you please any update on appointment.
Thanks.
Hi
Hi
Please keep us posted with updates, thanks so much for your patience!
Hi
Dear Jason,
I made my appointment but I have final question, is there any additional cost?
Thanks for the fast response.
Regards
Any additional costs or costs at all will be charged by the grid operator. If there's no ISRA at all, then grid operators decide whether the installation of an ISRA will come with the standard fee. I don't have an insight as to how high or low that fee might be, but that's something that'll be communicated once the installation is on its way.
Sorry for the lackluster response: providers don't decide on prices/fees regarding ISRA-point installations. They are governed by the grid operators, in this particular case KPN NetwerkNL. KPN Netwerk is the main administrator and operator for DSL-connections.
Thanks
You're welcome
You're welcome
Sure, Thanks
I see the appointment’s been arranged for coming Thursday, is that correct?
Yes, I am Waiting.
Awesome, thanks for notifying us and good luck on Thursday!
