PORT PROBLEM, a common issue
  • October 26, 2021
  • 178 Bekeken
Hi Guys,
My name is Eddie and I have a common problem… I want to open ports…….
I had a call with customer service < they couldnt help..
I tried Zyxel and they helped me, a good bit.. but still the ports aren’t open..
I checked out alot of the community issues and resolves… but still nothing is helping :(..
My IP 192.168.1.130 is pinging and working.. but port 44158 is still closed! I cant get info in our out..
I tried the firewall but it doesn’t seem to help..
I forwarded the IP.. everything is on.. I used DMZ and port triggering…. all doesnt seem to work..
I have a DSL connection. :) & Running mac.. do have a WINDOWS mirror :)
check out my screenshots for more information…
HELP PLEASE!!!
Beste antwoord door yalerta
@drinksonme
nmap shows that port 44158 on IP 192.168.1.130 is closed.
Why are you trying to change settings in the Zyxel as the closed port is on the device dd264db.home (192.168.1.130)
You should look on the database server and verify the port settings.
Opening ports on a router/modem is only needed if you want to access that device EXTERNAL.
Are you mixing up the idea where in a previous router setting a portmapping was setup like 44158 external to 3306 internal on a MySql database server? (just an example)
btw. It is possible to set the English language in the Zyxel
  • October 26, 2021
Hello @drinksonme
When you created a portforwarding rule in the Zyxel what did you fill in as "oorspronkelijke IP adres"? You can leave this field blank.
And is 192.168.1.130 a static IP address?
  • October 26, 2021
Hi @Waqqas !
thank you for your reaction!
I didnt fill this in. A nice guy from Zyxel did after doing a hour long teamview and testing. He thought that this might help? but ofcourse nothing did.. The port is closed with and without “oorspronkelijke IP adres”.
192.168.1.130 is the static IP yes.
I also changed the DHCP given IP’s as instructed in other discussions.
in oorspronkelijke IP adres we filled in my public IP address
Thanks buddy!!
Have been busy with this for 3 days now… its killing my mind!
  • October 26, 2021
@drinksonme
You can leave oorspronkelijke IP blank.
How did you assign 192.168.1.130 as a static IP adres? Did you do that via menu > netwerkinstellingen > thuisnetwerk > statische DHCP?
Or by changing the DHCP range via menu > netwerkinstellingen > thuisnetwerk > LAN configuratie > start 192.168.1.135 and end 192.168.1.254 for example so 192.168.1.130 is not in the DHCP range?
I think changing your DHCP range is the better option for a static IP address, give it a try 🤞
  • October 26, 2021
@Waqqas ,
Yes I did a few times. Im going to try to change the DHCP again and use a lower range as you suggest. Why is it made so difficult with this firmwire… :(
Thank you !!!!
  • October 26, 2021
I have tried everything and the ports WONT open at all….
This is pissing me off big time :).
going towards day 4..
  • October 27, 2021
@drinksonme
If you have adjusted the DHCP range and the IP is out of the DHCP range, delete the rule in statische DHCP and the other 4 rules aswell, restart your modem. Maybe it will work?
yalerta
  • October 27, 2021
@drinksonme
