Top-Up MBS not working
  • July 17, 2023
  • 65 Bekeken
Hello, I'm having issues replenishing MB's It has worked fine up till a few hours ago never had issues with it but now all of a sudden i get this
Beste antwoord door eric
Hi @David99434,
Yes, this was a technical problem from our side. Our technical specialists are working hard to solve it! I have just received word that it has been resolved and should now be working again. Could you try it now? It sometimes helps by restarting the app and your phone as well. If necessary, try using the browser or another device, such as a laptop. It should work then!
Kind regards,
Pharwin
Yes, here it works again!
  • July 17, 2023
I tried this as well, same result. So there is a techical issue. As stated,  try again later.
Pharwin van Odido
Hi @David99434,
Kind regards,
Pharwin
  • July 17, 2023
Hi @David99434,
Kind regards,
Pharwin
