Top-Up MBS not working
Hello, I'm having issues replenishing MB's It has worked fine up till a few hours ago never had issues with it but now all of a sudden i get this
Beste antwoord door eric
Pharwin van Odido schreef:
Hi @David99434
Yes, this was a technical problem from our side. Our technical specialists are working hard to solve it! I have just received word that it has been resolved and should now be working again. Could you try it now? It sometimes helps by restarting the app and your phone as well. If necessary, try using the browser or another device, such as a laptop. It should work then!
Kind regards,
Pharwin
Yes, here it works again!
  • 9122 reacties
  • 17 juli 2023
I tried this as well, same result. So there is a techical issue. As stated,  try again later.
Pharwin van Odido
Forum|alt.badge.img+8
Hi @David99434
Kind regards,
Pharwin
  • 9122 reacties
  • 17 juli 2023
Hi @David99434
Kind regards,
Pharwin
