I build on 2 locations in the T-Mobile Thuis network a similar setup: a Zyxel VMG8825 T50 modem and a NAS connected, and all is configured exactly the same at both sides. The IP address belonging to the NAS-URL of each NAS, is updated via DDNS (Setup in both Zyxel) with NO-IP.
1.When I try to connect from Laptop-1 to NAS-2 from IP = 85.144.x.y (=Zyxel-1) it fails.
2.When I try to connect from Laptop-2 to NAS-1 from IP = 87.208.x.y (=Zyxel-2 it works fine.
3.When I try from any other non-T-Mobile Thuis access point, or via Wifi Hotspot on the Mobile Phone, it works just fine.
4.Resetting Zyxel-1 has no effect.
Observations:
1.No ping works on the T-Mobile Thuis network
2.Routing from 85.144.x.y to 87.208.x.y domain fails
3.Routing from 87.208.x.y to 85.144.x.y domain works fine.
Can anyone advise whether I made a mistake, or is it a T-Mobile Thuis network configuration issue ?
Test started from: Amsterdam NL Starting Nmap 7.80 ( https://nmap.org ) at 2022-02-28 21:32 UTC Nmap scan report for y-x-b-a.ftth.glasoperator.nl (a.b.x.y) Host is up (0.011s latency).
Nmap done: 1 IP address (1 host up) scanned in 3.46 second
Test started from: Roubaix FR Starting Nmap 7.70 ( https://nmap.org ) at 2022-02-28 22:32 CET Nmap scan report for y-x-b-a.ftth.glasoperator.nl (a.b.x.y) Host is up (0.019s latency).
Nmap done: 1 IP address (1 host up) scanned in 3.26 seconds
A
Anonymous
0 reacties
28 februari 2022
EricSatu schreef:
@Gerrit078
Hi Gerrit,
Hier het test resultaat van Zyxel-2.
Groeten,
Eric
Test started from: Amsterdam NL Starting Nmap 7.80 ( https://nmap.org ) at 2022-02-28 21:32 UTC Nmap scan report for y-x-b-a.ftth.glasoperator.nl (a.b.x.y) Host is up (0.011s latency). Nmap done: 1 IP address (1 host up) scanned in 3.46 second
Test started from: Roubaix FR Starting Nmap 7.70 ( https://nmap.org ) at 2022-02-28 22:32 CET Nmap scan report for y-x-b-a.ftth.glasoperator.nl (a.b.x.y) Host is up (0.019s latency). Nmap done: 1 IP address (1 host up) scanned in 3.26 seconds
Nice…
Hmmm, 17 gefilterd 1 open (200). Dat houdt dus in dat op Zyxel-2 de Port-Forwarding niet goed is doorgevoerd d.w.z. het lijkt wel alsof iptables/nftables (= Firewall daemon) geen poorten opent naar de buitenwereld. Hoe ziet je hele port-forwarding schema eruit op Zyxel-2 ??
Ik gebruik poorten 200, 1001, 1443 en 1501 en forward die naar dezelfde poorten op een intern IP adres op Zyxel-2. Exact hetzelfde als bij Zyxel-1, waar alles gewoon werkt.
Het vreemde is dat vanbuiten het T-Mob netwerk de poorten wel open zijn.
A
Anonymous
0 reacties
28 februari 2022
Nee, dat zijn ze niet daarom zie je “filtered” de servers waar vandaan jij getest hebt zijn in Amsterdam (geen T-Mobile) en Roubaix France (geen T-Mobile). Dus voor buiten het T-Mobile netwerk zijn ze juist niet open als alleen poort 200. Als ze van buiten het T-Mobile netwerk wel open zijn, dan zouden ze status “open” (of "closed") moeten hebben.
Bij Zyxel-1 staat als het goed is je port-forwarding met ETH_internet, bij Zyxel-2 moet dit VD_internet zijn. Zou je bij Zyxel-2 eens de poorten op TCP willen zetten? Ben eigenlijk benieuwd of dit misschien iets doet.
@Gerrit078 Ik heb port 1001 en 1443 op TCP gezet. Kan nu niet meer het script laten runnen, maar door gewoon de url te gebruiken of Zyxel-2 IP adres met port nummer, werkt het niet. Kan dus aannemen dat de TCP setting geen effect heeft.
Heb je enig idee of de xDSL route effect kan hebben ?
A
Anonymous
0 reacties
28 februari 2022
Nee, deze kan dus gewoon weer op ALL, TCP heeft inderdaad geen zin.
Nee, ook dan zou port 200 dan gesloten moeten zijn. Als iets aan het route mankeert, dan werkt geen enkele port en zouden ze allemaal filtered moeten zijn. Denk dat het inderdaad ligt aan de firewall.
@yalerta , you are the man ! Ik ben in de NAS gedoken en vond een lijst met 129 geblackliste IP adressen in de Firewall, en mijn IP adres van Zyxel-1 stond daar tussen. Die heb ik verwijderd, en alles werkt meteen.
Hierbij wil ik jullie, @Jason , @Gerrit078@yalerta en @Pieter_B heel hartelijk danken voor jullie support om mijn probleem op te sporen met ideen. Ik ben uiteindelijk op het verkeerde spoor gezet omdat alles normaal werkte via een HotSpot verbinding.
Door vol te houden is het gelukt, en heb ik ook erg veel van jullie geleerd. Hiervoor mijn hartelijke dank.
Tsja, door de No-Ip dDNS stond ik ook lange tijd op het verkeerde been. Maar door een andere post op dit forum waar de poortmapping niet lukte bleek dit veroorzaakt door een 2e netwerkkaart in de Nas met verkeerde DNS binding/instelling. LINK
In dat topic had ik al 2 maal voorgesteld dat, in mijn beleving, de Nas het veroorzaakte. En dat bleek idd het geval.
Dat is echt geweldig nieuws! @yalerta Je hebt het wederom in goede banen geleid; dankjewel! Uiteraard aan een ieder bedankt dat jullie hier tijd instaken om @EricSatu zo goed te helpen! 😄👍
Bestand scannen voor virussen
We maken gebruik van 3 verschillende soorten cookies. Je kunt kiezen welke cookies je wilt accepteren. We hebben basiscookies nodig om deze site te laten werken, daarom moet je ten minste deze selecteren. Meer informatie.
