I have traveled to Turkey, I have contracted the indicated data package but it does not work in any way. I have rebooted the phone, I have made sure that in WiFi it works, I am connected to the Turkish phone network. So it must be a problem with T-mobile, which I can't call since the cost is €1.5 per minute, and on top of that they will charge me for the package I have contracted. Any ideas please?!
Hi
Did you enable 'roaming data ' in your phone?
You can also try-out to manually search for networks and try-out a different one.
Thanks for your reaction. Yes, I have tried everything but the phone is just able to find one network so it is the only one I can connect with.
Info for next travelers: I was visiting a shop from Turk Telecom, the one my mobile phone was 'connected' and the guy told me doesn't work. Companies sell packages but are useless in this region. So, I just hope T-Mobile can check I didn't spend/use my package and don't charge it in my next invoice.
