Wi-Fi not working
  • 16 May 2023
  • 8 reacties
  • 80 Bekeken
Hi, Today was the installation date for my subscription (my client number: UUN88468)
I tried several time to install the modem Zyxel T-54 by myself. This is on but I’m not able to connect my devices to internet, always says ‘'connected without internet'.
Please, help me! Can I get in touch myself with a technician as soon as possible?
Thanks
Ilaria
8 reacties
Attached some pictures
Badge +15
Hello @ifragliasso
On the 3rd picture the green phone cable needs to be plugged in the grey DSL port on the left.
Also you are not connected to the main KPN ISRA, please look for any of these :
Hi, This is the only one available. I found in all the home! :(
Hi, I checked with the previous tenant and he had the modem in the same location.
Could I ask with someone from the customer service to solve the issue?
Thank you!
Ilaria
Badge +15
Hello @ifragliasso
A moderator could send a technician if you cannot locate the ISRA point, have you also had a look in the fusebox? Maybe you'll only see a cable in blue mantle. You can also have a look in the crawling area for the cable. You can also find a telephone cable if you are living in an appartment.
Can be this one?
Now it seems working, but the 'internet' light is flashing.
Is it normal?
Badge +15
Is it normal?
@ifragliasso
That's good to hear! It's normal that the internet light is flashing, it means that data is being sent and received.
