EX5601-T1 and WX5600-T0 problem
  • May 8, 2024
  • 9 reacties
  • 903 Bekeken
Hello. I have a EX5601-T1 (FW: V5.70(ACEA.0)T56C_b10_0130) router and a WX5600-T0 (FW: V5.70(ACDW.0)b8) WiFi point. I used to be able to see the full topology in the router admin page, including all the devices connected to the WiFi repeater. Now when I open the page, it just shows the device connected to the router and not those connected to the repeater. I tried the MPro Mesh application as well and it says “Mesh: Down”. I factory reset both router and repeater and did the repeater setup again, but nothing changed. My repeater is working fine and I can connect my device to it, but those devices are not listed either in router admin page or in MPro Mesh application.
Beste antwoord door hamit
Hi @hamit, welcome to our Community!
This is indeed true. Since the new firmware of the modem, the B10, the modem does not communicate well with the wifipoint. As a result, the topology is not correct and the Mpro Mesh app is not fully functional. Do not worry, this does not affect the operation of the wifi point with the modem. It's just that you don't see it the way it should be.
Hi Tommie. Thanks for the explanation. Is there any way this would be solved with an update? I sometimes need to see the devices connected to my repeater to get their IP addresses, and this problem is making it really difficult. Your help is greatly appreciated.
9 reacties
  • May 10, 2024
Ishana van Odido
Hi @hamit, this will be resolved as soon as possible with a firmware update of the WX5600! We will let you know immediately when we have more information about this. Greetings, Ishana
  • July 13, 2024
Hello,
Is there an update about this issue?
I have odido sinds yesterday.
Yesterday i have settup everything and my topology of my network was perfect,
At night i got the new firmware B10 and now my topology is not correct.
When is a new update available? (this toppic is more than 2 months old.)
kind regards,
J
  • July 13, 2024
Hello,
kind regards,
J
Hello Jawie. It doesn't seem to be fixed. I still have the same problem. @Ishana van Odido could you please update us on the latest status of the update? It has been more than 2 months since my post, and the problem still exists.
Regards,
Hamit
We are still working on a fix @hamit. Sorry for the inconvenience!
HI ​@Tommie van Odido any update on this?
Hard to debug connectivity issue when the mesh page is broken.
It says some clinets are on LAN while they are actually on WiFi
  • November 29, 2024
Hi ​@Tommie van Odido
It’s been 6 months since my original post, and the problem is still there! This is not the place to mention many other problems I’m facing with Odido, so I guess it’s time to switch providers!
  • January 17, 2025
Hi! Ik wacht ook al geruime tijd op een fix voor dit issue, kan hier wellicht bij Zyxel zelf druk op worden gezet door Odido? Mijn satelliet zit nog op b8 terwijl het modem zelf op b10 zit, en het netwerk werkt gewoonweg niet lekker hierdoor op sommige punten. Wanneer komt eindelijk de firmware-update die het oplost?
