Fiber optic installation
  • 18 April 2024
  • 98 Bekeken
Hi,
I need to make an appointment for a technician to come to install the fibre optic modem and connect the internet. The problem is the connection point is in a meter cupboard (I think!)
which doesn't have a socket! And it isn't possible to implement extension lead either. What is the solution??
Also is either of those the actual connection point?
Badge +15
Hello @agnesw12
The black device on the 2nd photo is the connection point for fiber, maybe the technician will replace it with another one.
Hello @Waqqas
That's what i thought, thank you! Problem is there's no socket in that room so no power 😕
Badge +15
@agnesw12
Well you'll need atleast 1 socket there, maybe someone can install 1 socket for you? You can also ask Guidion but please call them first so they can make preperations.
https://www.odido.nl/service/bestelling/internet-tv/installeren/installatie-door-monteur
The router can be installed in another room using a long internet cable.
