Will T Mobile work for my apartment?
  • mei 24, 2023 1:31 p.m. UTC
  • 46 Bekeken
I live in Almere, 1334 BM.
In early 2022, I took Ziggo. After receiving the devices, I couldn't install it myself. Then Ziggo technician came and he spent quite a few hours to set up everything.
I have attached photos of my current internet setup. The router had to be  set in the apartment switchboard outside in the lobby. As the wifi speed was slow, I was given three wifi boosters, too.
Question: Will T-Mobile work for my apartment?
Hello @mochow13
If you are able to order T-Mobile then it should be possible, what is the box where the orange cable goes in? Looks like a Fiber connection point.
6 reacties
  • mei 24, 2023 1:32 p.m. UTC
  • mei 24, 2023 1:47 p.m. UTC
Hello @mochow13
  • mei 25, 2023 3:22 p.m. UTC
  • mei 25, 2023 3:23 p.m. UTC
Hi @Waqqas, dankuwel for your reply! I attached a photo of the box where the orange cable comes from.
  • mei 25, 2023 3:24 p.m. UTC
I guess I can then order T-Mobile to replace my Ziggo? I am not familiar with the process. How would the do the switch? Will there be a possible downtime of connectivity?
  • mei 25, 2023 3:27 p.m. UTC
@mochow13
Fiber from T-Mobile should be possible at your address, than you can decide to lay an internet cable to your appartment and install the router there or use a wireless system.
If you use the overstapservice then there should be no downtime, maybe a few hours.
