Hello, I ordered my Fibre on the 5th of October, the earliest an installer could come by was last night(26th of October). The installer installed everything except that the Fibre light is off. He said I should just contact Odido to get it activated. He made it sound quite trivial and that it would be done easily. I also assumed any work on Odido side would’ve been done between the 5th and 26th, since you should know that is when the installer will be coming by so that my connection could be ready.
Could this be done relatively quickly?
I have turned this box as well as the modem off a couple of times already, but not helping with the Fibre light.
My order status still shows as “Onderweg en installeren” not sure whether that could also be causing this, or at least not helping.
Thank you in advance.
