DX5401-B1 interface settings missing
  • 23 July 2024
  • 28 Bekeken
Hi,
I just got Odido fiber internet working, but when I log into the modem’s interface, it looks like I’m missing some settings, particularly QoS settings. These settings appear to be available in the user manual I found online. I also tried to check the software version and update it, but the relevant options seem to be missing under Maintenance. Please refer to the attached screenshots for more details.
Thank you.
Hello @davgrig
This is because Odido has a custom firmware on their routers so not all settings are there for the customer.
Thanks @Waqqas , I was on the call with Odido, they didn’t mention it, rather found it strange, even sending me a technician, which I guess is useless. Any other workaround ?
@davgrig
If you want a modem/router with more functions than I suggest to use your own router, it needs VLAN capability for it to work with Odido.
A technician cannot do anything in this.
