Valorant Ping problem Fiber
  • 18 May 2023
  • 43 Bekeken
Hi there, I play Valorant at Bahrain server, despite the availability to play at good ping in EU I play there because of my friends.
I used to get 95ms stable ping. From past 1 month I getting 140ms ping. I tried to reset my router but it is still 140ms. I really having hard time playing at such a high ping.
On the other hand my friend in NL has KPN he is getting ping of 85ms on Bahrain Server.
My question is how is he getting 85ms ping even though Im also on Fiber. Is it related to the provider? Can Tmobile fix this for me?
Hello @m.zulfiqar
The problem could be that your connection is taking a longer route to reach the Bahrain server compared to your friend.
An option could be that you and your friend perform a trace route to the server and compare it to see if you have a different route.
@Waqqas If I found a different routing for my friend, is there any possibility I can ask T-mobile to change my routing?
Routing in the core network is not set per customer.
