Regarding Port Forwarding DX5401-B0 - do not work
  • mrt. 6, 2023 11:54 p.m. UTC
  • 577 Bekeken
Hi
I am trying to configure port forwarding on
Tmobile wifi router.
When i try to access the same server its working.
But when i try to access it from internet using my public IP this does not work.
Any suggestion how this needs to be configured.
Or is there any way i can setup VPN to connect to server or Tmobile router from outside?
I tried to disable FIREWALL + Allowing the security from LAN to WAN and WAN to LAN but still no luck.
Any pointer please.
Hello @klakh
Here is a step by step guide on how portforwarding works on the Zyxel-T54:
https://community.t-mobile.nl/bekabeld-internet-492/port-forwarding-zyxel-t50-met-glasvezel-wil-echt-niet-werken-323803/index2.html?postid=1578994#post1578994
I can see that the created line is not active as you can see under status.
  • mrt. 7, 2023 8:54 a.m. UTC
Hello @klakh
  • mrt. 7, 2023 11:46 p.m. UTC
Hello @klakh
Hi @Waqqas I have followed the link which you shared but still the same issue this feature does not work and when i check the port check 4433 port is closed on my public IP which i am getting from Tmobile.
Also by looking into some comments in your link i think this issue is for many people and seems like no fixed.
Can you please share some update.
Also to mention: I have activated the NAT as well but still no luck. and disabled Firewall + DDOS feature from model still no luck,
  • mrt. 8, 2023 11:54 a.m. UTC
@klakh
It's not safe to turn off the firewall but is the device for whom the port is opened connected directly to the Zyxel and does that device have a static IP address?
  • Odido medewerker
  • mrt. 8, 2023 12:39 p.m. UTC
@klakh
What happens if you try to reach the service behind that port from your mobile connection for example.
Online port checks sometimes give the wrong result.
  • mrt. 8, 2023 7:28 p.m. UTC
After making some changes on server side routing it's good now. It's working perfectly.
Thanks a lot for assistance
