After 2 months of wait i am upgraded to 8Gbit/s, but my speed is 5/down 3/up 🙁 whats wrong?
  • 10 February 2024
  • 91 Bekeken
Dears,
I was a long time user of 1 Gbit/s fiber optic and i was receiving always 980/980.
Now after upgrade to 8 Gbit/s i am not getting more than 5 down and 3 up!
any help?
Beste antwoord door Tommie van Odido 13 February 2024, 09:58
Dear Tommie of Odido can you help me plese?
Hi @senad.aruc, good thing you started a topic for this. I went straight into it for you and see that you cancelled the engineer? Do you have a reason for this? Because the engineer has to come by because you have a Point to Point connection and this has to be rerouted in the district exchange. The ONT and T-75 are then installed immediately. Then the technician should set the order administratively to complete. I will forward below a list of what needs to be done on the various technelogies. I have re-directed Guidion for you, schedule the appointment and it should be fine!
Netwerktype
Wel/Geen nieuwe ONT
Patching nodig?
Guidion nodig?
GPON
Wel nieuwe ONT
Nee
Ja, voor ONT
XGSPON
Geen nieuwe ONT
Nee
Nee
PtP
MC wordt nieuwe ONT
Ja
Ja, voor ONT
Dears,
any help?
Dears,
The engineer came and installed the equipment! i think they made 2 appointments so i canceled one of them but the engineer came Saturday and installed the equipment.
Thanks,
Hi @senad.aruc, I see that two different appointments were made at the same time. Just schedule the appointment with Guidion to be sure, he can check everything for you!
Ok, so if they can fix the speed issue then lets make a second appointment.
